2017 Iron 883 RHCM not working/can't start
Can not start bike, no right hand controls are working. Chased wires and nothing is bent or chewed. Took apart the module but nothing to see really...
Was not ridden for the winter/spring, bought new and only 180 miles on it. Replaced battery, all lights work besides hazzards and right blinker...WONT start!
Help????
Help????
Help????
Help????
I am sorry to say that I have no clue where those connectors are but can provide the link to the wiring diagrams: https://serviceinfo.harley-davidson....80be48d4!!3!69
Since the engine light came on you should check for codes:
Harley Trouble Codes
If you don't have the owner's manual you can download it from the Harley website.
On the CAN bus bikes the run/stop switch is not part of the network. Looking at a wiring diagram the engine stop switch as it is called has a W/GY wire from it to the BCM Engine Stop Switch Input. That would account for the fuel pump coming to life when the switch is operated.
So if the hazards and engine start switch do nothing then either the switch itself is faulty or the module in the RHCM is faulty or something has happened to the wiring.
With that as a fault there ought to be a DTC stored. Harley Trouble Codes (fuelmotousa.com)
One other check, does the brake light come on when you operate the front brake?
I have a 2017 iron 883 and this seems to be a big problem on this model. Everything works but the rhcm. Checked all connections and they looked good. Ordered a new rhcm from Harley but they are back ordered over a month and not cheap. Is there a way to troubleshoot the rhcm to see if that is the cause.
