Torque Specs for Derby Cover
Old 06-29-2019, 11:38 AM
08xl1200r's Avatar
08xl1200r
08xl1200r is offline
I use a T27 bit and a hex drive handle for stuff like this, gives a better feel for torque and makes it more difficult to over torque fasteners. Do have a few torque wrenches but would not use them for this job...
Midpegs (06-30-2019)
Old 06-29-2019, 12:29 PM
Carlos G Godfrog's Avatar
Carlos G Godfrog
Carlos G Godfrog is offline
What about a length of all-thread, and an acorn. Good looking, and you won't strip the nut or stud. If you go all Magilla Gorilla on it, the stud can be unscrewed and not screw up the cover threads.
Old 06-29-2019, 01:15 PM
cj24's Avatar
cj24
cj24 is offline
Ok guys didn't get started until this morning and had to build a little stand out of 2x6 first.
Anyway... process went smooth. After seating screw and turning clockwise 1/4... it was about where it was before. But it gets hot where I am... so i did mid point between 1/4 and 1/2.
Put little grease over o ring to help seat and followed recommended tightening pattern. I first tightend by hand. Decided to use 1/4 beam torque wrench... first patern at 40 in lbs... then pattern again at 80.
About to test her out.
Old 06-29-2019, 06:18 PM
cj24's Avatar
cj24
cj24 is offline
Well the ride went well... no seeping. I was hoping that this would help with the clunking but it is about the same... maybe a little better. I find the only way to shift without the clunk is just the right rpms and shifting very quickly. I know that the clunk is normal supposedly... but maybe try to adjust cam chains? Could this help?
Old 06-29-2019, 07:25 PM
apache snow's Avatar
apache snow
apache snow is offline
You don't have any cam chains. The cams on a sportster are gear driven. And for the record mine does not clunk. You might try adjusting your primary chain.
Old 06-29-2019, 08:06 PM
cj24's Avatar
cj24
cj24 is offline
Lol too funny! Thanks!
Old 06-29-2019, 11:17 PM
handirifle's Avatar
handirifle
handirifle is offline
Received 1,709 Likes on 1,141 Posts
This is what I use for inch pounds. Got it to mount scopes but is handy for the bike too.
https://www.ebay.com/p/Wheeler-Firea...nid=1908126902
Old 06-30-2019, 02:12 AM
Midpegs's Avatar
Midpegs
Midpegs is offline
Received 1,119 Likes on 631 Posts
Originally Posted by VAFish
If it's already weakened my chances of stripping it snugging it up by hand are just as good as using a torque wrench. But if I use a properly calibrated inch/lbs torque wrench all the time I won't weaken the threads in the first place, just tightening them up "Snug Enough" might weaken them because my version of Snug might be different then the spec.
Engineers design things and set specifications for a reason. Follow the specifications and you will reduce your chance of screwing things up.
When we say Torque Wrench we aren't talking about a 3 foot long breaker bar, we are talking about a precision tool that measures twisting force.
Buy a decent 1/4" drive torque wrench calibrated for inch/lbs and use it.
Not if I do it .
I was assuming that a previous owner who also didn't know how to tighten a simple retaining screw might have been there first . Thanks for explaining what a torque wrench is .
Old 06-30-2019, 02:18 AM
Midpegs's Avatar
Midpegs
Midpegs is offline
You might be referring to the primary chain . Inspect and adjust according to the specs in the owners manual.
Old 07-01-2019, 01:00 PM
cj24's Avatar
cj24
cj24 is offline
Yes, thank you. I remember awhile back reading about adjusting a "chain" to help with clunk. Additionally mentioned by another poster ... I will give adjusting the primary chain a shot. Will read up and watch vids on how to do this
Quick Reply: Torque Specs for Derby Cover
