Sportster Scrambler Project
Old 04-01-2020 | 12:47 PM
whylee's Avatar
whylee
I think the 2 3/4 would flow with the tank alittle better myself, and give alittle extra cush.
  #172
Old 04-02-2020 | 06:04 PM
Gone Blue's Avatar
Gone Blue
Yes maybe. I think if I have the upholstery guy make the sides of the seat at 2.5", the center pleated section likely will be up near 2.75"? G.B.
  #173
Old 04-02-2020 | 06:08 PM
Gone Blue's Avatar
Gone Blue
FYI.......For anyone considering building a Scrambler type bike, this wheel is back in stock. This wheel has been out of stock for almost a year and is a nice option. It was really difficult for me to find an 18 x 2.5" rim to build the rear wheel that I did.. To my knowledge, no one else is offering a Harley wheel of this size? G.B.
http://www.tcbroschoppers.com/chrome...1982-2004.html
  #174
Old 04-02-2020 | 06:29 PM
Gone Blue's Avatar
Gone Blue
Finishing up a couple loose ends. Test fit rear turn signals. Need to wire them to the stock turn signal connectors I cut off the stock Harley turn signals.
I also welded tabs across the raised bead in the rear fender to route and contain the rear lamp wiring.
And lastly, I finally found some foot peg extenders. Since my RSD Tracker pipe if made for a 2004' and newer Sporty, the pipe was really close to the right side foot peg. My right ankle would have been up against the pipe. So I found some 2 1/4" Kurykyan foot peg extenders. These come in both 1 1/4" and 2 1/4" lengths. They are not cheap and only are sold in pairs, but I think my right ankle will appreciate it. G.B.
Rear turn signals
Retaining tabs for rear tail lamp on rear fender
Right side foot peg extender
Right side foot peg extender top view
  #175
Old 04-02-2020 | 08:49 PM
handirifle's Avatar
handirifle
Yea that pipe would have your ankle pretty well done in about 20 minutes.
  #176
Old 04-02-2020 | 08:50 PM
handirifle's Avatar
handirifle
Is that a metal tube for the wires?
  #177
Old 04-02-2020 | 08:53 PM
Gone Blue's Avatar
Gone Blue
Haha, I know right?
  #178
Old 04-02-2020 | 08:56 PM
Gone Blue's Avatar
Gone Blue
I think you asking about the rear fender? The fender has a raised bead down the center. The 5 pieces I welded on the underside of the fender span across the convex side of the bead and produce a channel to run the wires in. Make sense? G.B.
  #179
Old 04-03-2020 | 01:17 AM
handirifle's Avatar
handirifle
Yes I was asking about the rear, and that was what I thought you were talking about, but it looks like a metal tube is under those span pieces. Maybe optical illusion?
  #180
Old 04-03-2020 | 01:20 AM
handirifle's Avatar
handirifle
After my run today, I decided my next fork oil change will be to a lighter weight oil. Its a bit harsh, but it does seem to handle well. As long as I avoid those curves with the undulating bumps in them, I do not get the rear end hula dance. I wonder how other bikes handle that area?
Quick Reply: Sportster Scrambler Project
