Sportster Scrambler Project
#162
Thanks handirifle for your suggestions with boxing in and supporting the front hook mount! G.B.
#163
No, the seat pan does not touch the fender just hovers over it as it sits on the original part of the frame and new seat loop. I am going to weld a couple mounting tabs to the inside of the seat loop and then weld (2) bolts to the seat pan that would drop thru the tabs. I need mock this up to make sure it is possible to use studs on the seat pan with the angle and rotation for loading and removing the seat. Worst case I will weld nuts to the seat pan and then use bolts up thru the mounting tabs and thread into the seat. Using weld nuts on the seat pan would be a blind operation when installing the seat. Not impossible but a little slower and a little more difficult. G.B.
#164
Interesting on the steel pan. Would really like to see what they end up doing. I can only reference from seats I have redone on old bikes and quads.
I get it now on the tabs for the hold down bolts. For some reason before I could not picture in my head (too much garbage flopping around in there, I guess) what you were describing. I do now.
On the suggestion, happy to be able to offer any assistance, no matter how miniscule.
Gone Blue (03-29-2020)
#165
Playing around with seat thickness today. Hoping to get the seat pan to the upholstery shop this week if they are still open and I want to be able to tell him how thick to make the seat? Kind of hard to get a good view of the seat thickness differences with all my crap behind the bike. I think I am going to go with the 2 1/2" seat thickness which is the thickest I was considering. I want the top of the seat to be in a line with the bottom of the gas tank. G.B.
2" thick
2 1/4" Thick
2 1/2" thick
2" thick
2 1/4" Thick
2 1/2" thick
#167
#169
whylee I made up a 2 3/4" tall seat template as I thought it was a good suggestion worth checking out. Still leaning towards the 2 1/2" but the 2 3/4" doesnt look too bad?
2 1/2"
2 3/4"
I welded rear mounting tabs on the seat loop and a couple bolts on the seat pan tonight. This works out great and makes a clean simple seat install. So all I need to do tomorrow is spray paint the seat pan and then call to see if my upholstery guy is still working and if I can drop off the pan? G.B.
2 1/2"
2 3/4"
