Battery connector molten
Old 06-23-2019, 08:47 PM
carider48's Avatar
carider48
carider48 is offline
Stage I
Default Battery connector molten
Hey guys,
I recently installed a new battery on my '13 Forty-Eight. Yesterday I was about to go for a ride and the engine started to cut out every couple seconds. I checked the battery and found that one of the connectors had melted:
Does anyone know what happened here and how I can make sure it won't happen again?
Old 06-23-2019, 08:54 PM
gillie64's Avatar
gillie64
gillie64 is offline
Bolt was not tight, Or came loose.
The following 4 users liked this post by gillie64:
Chasingdrakes (01-22-2022), Lakerat (06-24-2019), LordSargon (01-15-2022), Midpegs (06-24-2019)
Old 06-23-2019, 08:56 PM
fireman64's Avatar
fireman64
fireman64 is offline
Received 1,583 Likes on 329 Posts
What he said...
Old 06-24-2019, 12:01 AM
DB429SCJ's Avatar
DB429SCJ
DB429SCJ is offline
Did the new battery come with spacers?. If it did, you must put them in between cable and battery post. Without them, the cable will not tighten up all the way.
Old 06-24-2019, 07:57 AM
470004's Avatar
470004
470004 is offline
Received 16,307 Likes on 6,747 Posts
Something melted the battery terminal, maybe a short?
Old 06-24-2019, 08:28 AM
hammer6315's Avatar
hammer6315
hammer6315 is offline
Originally Posted by fireman64
What he said...
Old 06-24-2019, 09:46 AM
Midpegs's Avatar
Midpegs
Midpegs is offline
Received 1,119 Likes on 631 Posts
What everyone said . That's been sparking away like an arc welder !
Old 06-24-2019, 10:36 AM
VAFish's Avatar
VAFish
VAFish is offline
Received 3,207 Likes on 1,655 Posts
What he said, with that type of battery you need a spacer between the power connectors and the terminal. Without it the cable does not get tightened all the way up to the terminal.as it wiggles it arcs, the more it arcs the more it melts the terminal.
At this point you need a new battery. If it doesn't come with spacers you need to get some or use some washers stacked up.
Old 06-24-2019, 01:20 PM
Midpegs's Avatar
Midpegs
Midpegs is offline
I don't think you need a new battery just yet . If you fabricated a piece of steel with two bends and a hole in it and carefully filed away some of the melted bits I think you might be able to salvage it . It's worth a go . Looking at it again , you could also make a 90 degree adapter from a strip of steel and use the hole in the top of the battery post . If you are feeling really creative you could build a little wooden mould around it , protect the battery with aluminium foil and pour some molten lead into the cavity . You can melt lead in a spoon on a domestic cooker by the way .
Old 06-24-2019, 01:22 PM
Scudda's Avatar
Scudda
Scudda is offline
Received 3,365 Likes on 970 Posts
^^^^^^^ This right here!!! I had that happen to me but not as bad.....The batteries come with spacers that look like thick washers..USE them!
Quick Reply: Battery connector molten
