New brake line for z bars with 6 inch rise?
Ok so I'm about to attempt to do a handlebar swap for the first time. I've got a stock Iron 883 with stock bars(4 inch rise I think). It looks like I've got plenty of slack in my throttle cables and clutch line, and a little in my brake line. My question is, am I going to need to replace my brake line to increase rise by only two inches?
I've attached a few shots of the brake line as of now with the current bars. As a side note, does the pigtail and the stretched rubber grommet on the brake line seem normal?
Thanks for any help!
You may be able to get away with keeping the stock line if it is only 2 inches. Only way to tell is to try it, unless there is someone on the forum who has made this exact switch and can tell you. I am hoping that is the case and someone else chimes in with a definite answer for you.
Even if you don't need to, I would recommend switching the brake line anyways. You can make your own, or buy a nice one from @Magnum Shielding. They make great stuff.
I used Russell when I changed to 8" mini apes and 4" over tubes … simply measure from the master cylinder to the caliper and order that length … the fittings you will need to order will give you the slack you need … Russell is a one piece hose and you get the fittings you want for the ends
I would just replace it to get rid of the 3 piece line. I used a braided stainless Magnum Shielding Build Your Own kit. Cut the line to length and assembles in 5 minutes. I ordered mine with a 10mm 60° banjo fitting for the caliper and I chose a 10mm 180° fitting to match the lines on the bars I used.
