Electrical grief - brakes
I'm banging my head against the wall here. 2003 Hugger.
Turn bike on. All electrical works. Brake light is on. Squeeze front brake, brake light dims. Press back brake - nothing happens.
Is the rear brake pressure switch kaput? Or is there a greater problem afoot?
Thanks in advance,
Cannon
Thanks in advance,
Cannon
Received 1,297 Likes
RE: Electrical grief - brakes
ORIGINAL: Jonny Cannon
Thanks in advance,
Cannon
Thanks in advance,
Cannon
1- Front brake switch is bad; stays "closed" all the time.
2- Short in wiring causing power to brake light all the time; not likely since light dims when front brake handle squeezed.
Start with checking that front switch.
This all is predicated on you mean the brake light stays on when "Press back brake - nothing happens."
