Low RPM sputtering
Low RPM sputtering
I have an ‘07 1200 Sportster that I bought last winter. The bike has a K&N air filter and unbaffled Vance & Hines drag pipes. It’s also EFI- I’ve never owned a fuel-injected bike before.
So, when trying to “lope” somewhat quietly through a town at low speed/barely-cracked throttle, the bike will occasionally sputter and run strange. If I downshift and raise the rpms a bit, it’s fine. Just happens at barely-cracked throttle.
Any ideas what might be the problem? I don’t know if anything has been done to the computer. I’m assuming that more air (K&N filter allowing more air), and better breathing exhaust might mean that it needs some sort of EFI adjustment to add more fuel, and I suspect this was never done. Theories?
Question- how do I get this diagnosed? If it IS the computer, what does it cost to replace with one modified for my intake/exhaust situation?
Many thanks!
Many thanks!
Mine did this too, and I have been "tinkering" with my ViED system to balance the cylinders, going by plug color. The ViED system allow for each cylinder to be adjusted independently. I know a good tuner would be more accurate, but so far it seems to be helping.
It has helped, but I still get some sputter, not nearly as bad.
Question-how do I get this diagnosed? If it IS the computer, what does it cost to replace with one modified for my intake/exhaust situation?
Many thanks!
Many thanks!
FLXSporty (06-09-2019)
Kawickrice
17
08-12-2013 10:51 PM
