Won't shift
Old 05-30-2019, 07:19 PM
Jesse Guerndt's Avatar
Jesse Guerndt
Jesse Guerndt is offline
6th Gear
Default Won't shift
So I accidently laid down my 2014 iron 883 going about 3-5 mph. Bent the licence plate a bit and the LEDs on the front with neutral and stuff wasn't working. I did get them working. But when I go to shift it does not seem to wanna shift at all. I did at one point manage to get it into neutral to get it home. Then it was shifting really hard and loud. When trying to go up it doesn't seem to shift at all and can just go down but seems to not shift occasionally it will shift but sounds very hard. But the shift left and peg seem loose I laid it down on the left side tranny side. Was wet and on gravel and only scartch I could find was the bent licence plate. Could that just need tightened or should I bring it into a Harley dealer.
Old 05-30-2019, 08:55 PM
Zateeva's Avatar
Zateeva
Zateeva is offline
at 3-5 mph......you dropped it, not layed it down.......scratches are nothing.....other things hit the ground hard i would assume
did you try and hold it up when it happened, or did all the weight hit the ground
Old 05-31-2019, 12:42 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
Disconnect the forward control and try shifting with the transmission end only by hand, if it shifts good your problem is with the forward control, if it doesn't then the shift shaft is bent or something inside the cover like a shift pawl is damaged.
Old 05-31-2019, 08:06 PM
Jesse Guerndt
6th Gear
Default Thank you.
Thank you I think my clutch pedal is a little bent. But the rod connecting the clutch petal to the tranny got pushed back a bit and happened to be striped to hell. But 9 hours later and 3 guys we got it drilled out and I moved it forward into a different groove. But I still need to.replace it. It took alot of.hits from the drills but the new bolts held tight on a few runs but any idea on just the name of this part. Where it connects to the grooves coming out of the tranny.
Old 05-31-2019, 08:22 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
Old 05-31-2019, 09:05 PM
Jesse Guerndt
6th Gear
No it's number 8 it's a forward one. Straight up.and down. Maybe I said the wrong part.
Old 06-01-2019, 11:30 PM
Jesse Guerndt
6th Gear
I was unable to find the correct part.
Does anyone have any idea of the instrument wiring harness for this model (68813-07) but doesn't seem to be for my model. But when It tipped all the instrument lights stopped working. IE. Neutral,turn signal, High low beams. Just the indicator lights.
Old 06-02-2019, 12:45 AM
Midpegs's Avatar
Midpegs
Midpegs is offline
Received 1,119 Likes on 631 Posts
With the greatest of respect , if you do not yet know the difference between a gear lever and a clutch lever , you would be wise to take the bike to an HD dealership as you originally suggested .
CoolBreeze3646 (06-02-2019)
Old 06-02-2019, 09:51 AM
Jesse Guerndt
6th Gear
A. Not helpful, but I managed to fix that problem with not much help. But thanks that did.
B. There was a time you did not yet as well. It's called getting in things tinkering, playing, upgrading, and fixing. It's how you learn things or go to school on it. But, I appreciate your comment. I found the wiring diagram already for the bike and narrowed down what I need to look for.
Old 06-02-2019, 10:15 AM
Midpegs's Avatar
Midpegs
Midpegs is offline
I'm sorry if I appear to have offended you , that was not my intention at all . To be honest though , I have never referred to a gear lever ( shifter ) as a clutch pedal . This is because at the age of 58 I have never owned or driven a car . I suppose if you devote your life to motorcycles it's easy to forget that there are others for whom a bike is just another leisure persuit. My intention was to recommend that your interests might be best served by placing your bike in the hands of qualified Harley Davidson technicians but I could have chosen my words more carefully . All the best, hope you fixed it ok .
Quick Reply: Won't shift
