Won't shift
I'm sorry if I appear to have offended you , that was not my intention at all . To be honest though , I have never referred to a gear lever ( shifter ) as a clutch pedal . This is because at the age of 58 I have never owned or driven a car . I suppose if you devote your life to motorcycles it's easy to forget that there are others for whom a bike is just another leisure persuit. My intention was to recommend that your interests might be best served by placing your bike in the hands of qualified Harley Davidson technicians but I could have chosen my words more carefully . All the best, hope you fixed it ok .
Midpegs (06-02-2019)
The shaft coming out of the tranny is called a shifter shaft or shifting shaft, depending on what part of the country you're in. If you stripped the splines on that shaft, honestly you should take it to the dealership. However, there are aftermarket shift linkage kits that are specifically designed for shifter shafts that have been stripped. I installed several of these kits when I worked as a service tech at a Harley Dealership. As far as the lights and indicators, you should check the wire connections inside the button assembly on the left handlebar. Even a lay over can cause wires inside the button assembly to come loose if the handlebars are turned, and the shock of a straight hit can jar it enough to break the thin soldering used on the buttons and switches. If all of the wiring connections are good, you should take it to a dealership as they can hook it up to the computer and find any open or shorted connections without having to tear the harness down.
Jesse Guerndt (06-02-2019)
Received 22,124 Likes
Thank you so much I didn't strip the splines but I was worried it was threaded on the shifter shaft but didn't look when I put the new bolts in .I am unable to forward shift lever all the ones I see are mid, but I just found the dealership print out so now I have a part no..34670-06.Thank you I will check the assembly and see if anything broke or came loose because. It was working on and off if I pushed a certain way. Everything works even the speedometer lights just no indicator lights. I'll try and find the expanded diagram for the handbars nothing should fall out I'm hoping hhah.
Make sure you check all the fuses etc as one of those could have come loose, i think they are still on the left side under the cover, your owners manual will give you the location.
No problem. Even though I don't wrench professionally anymore, I do most of my own work and I've had this issue in the past. I ended up warping my shift linkage enough that it wouldn't shift out of neutral...it was in neutral when I decided to lay it over in the driveway. The linkage bent inward towards the case, which put too much pressure on the shifter shaft. Ended up having to replace the seals as well.
I bet that ran a ton of money to fix. I know Harley parts are insane and I live in a small town think we may have one junk yard.
I did find out if I'm in gear 1 or 2 and not started my own oil light will come on. Not sure how or if this helps me at all. Turn signals would be the most important ones to have.
Checked all the fuses. The weird thing when I have it in gear and off my oil light will work on the indicator light then if I hit a turn signal it will flash and turn off when I turn it on. Once I turn the bike on still no indicator lights working. So I'm guessing a return got damaged. I'm trying to locate the connector. I've seen there is a soldered wire and there's well I can check.
