USB Charger
USB Charger
Hello All,
I've seen various posts about what to get to set up a USB charger on your bike. However looking for some more details on how to route everything. I have an Iron 1200. It has a SAE quick disconnect tail on the left side under the battery cover. It is low and faces backwards. I have a Batter Tender USB that I was planning to mount inside the front faring. I want to zip tie and route a SAE extension cord from the pigtail to the charger. However most of the good points I see are on the right hand side of the bike. I know to keep the wires away from the engine but looking for advice on best way to do so. Any photos and advice would be appreciated.
Thanks!
Thanks!
I would just use the SAE plug for what it is for, charging the battery with a trickle charger and buy a new usb socket that you can wire in your headlight. I always
do it like that, take the power for the new usb in the headligt, easy and no extra wires to put on the bike because everything is already in the front.
The picture is just an example, there is a lot of choice in this USB sockets.
I have used my quick connect and the HD usb cable on my bike on longer trips but now that I have done some work I am adding a longer quick connect cable and running under my tank so its upfront but conceiled and out of the way. There are a lot of options and just depends on how you want to do it. Below are some examples and what I am using and will run the cables tomorrow so I can post some pics after.
HD USB
https://www.harley-davidson.com/stor...to-usb-adapter
SAE to 2 pin
HD USB
SAE to 2 pin
Hey NHIron1200, I finally finished up the small projects on my bike to get it ready for the summer, I just posted the pics of my USB install underneath my gas tank. A couple of thoughts, I have a tank lift so it makes it easy to route the wires and I used a 2ft quick connect cord and it stretched just right to be hidden but you might consider a bit longer to have room to play with so maybe like 2 1/2 ft? Also I couldn't remember if my HD USB adapter was broken or not and I had a battery tender one, so I used that one. Anyways here is a link to my thread with pics: https://www.hdforums.com/forum/sport...-bobber-2.html
I'd lift the tank and simply run it under the tank. You can zip tie the cable to the frame
For mine I normally run a tank bag so I just route the wire into the bag and toss my phone in there. I am getting a handlebar mount for my phone so I can have traffic info when needed and will probably simply run the wires under the tank bag.
I use the SAE connector because I already have a connectors for heated gear, jump starting the bike (SAE adapter on it), and two GPS units.
Here is what I used on my 2014 Forty-Eight.
https://www.revzilla.com/motorcycle/...ide-usb-outlet
It was pretty easy to install. I had a 1.5" lift on the tank already so getting the additional wired tucked wasn't difficult. Ran it right to left to the battery side and looped it through the frame. Attached the ends to the battery leads and it was up and running. I didn't have to install anything else. But, I do have a Anti-gravity lithium battery installed which can handle a bit more of the load.
