Possible fork leak ?
Old 05-20-2019, 08:00 AM
Mihail Petev's Avatar
Mihail Petev
Mihail Petev is offline
Default Possible fork leak ?
Hi there, I just noticed some rust like traces around one of the fork tubes and wanted to check if it is a fork leak before i start pulling the fork apart a it is quite a job turns out.
Old 05-20-2019, 09:01 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,868 Likes on 2,430 Posts
Wink
It's not that much of a job, old chap. You can probably do it on the bike, simply remove the sliders, wheel and fender, disconnect the calliper. That rust 'leak' is odd, but removing the sliders will reveal what is going on. It will help greatly to have the FSM!
Sorce (05-22-2019)
Old 05-20-2019, 09:08 AM
Mihail Petev
Thanks !
I have the service manual but that is why I was thinking it is a lot of work - I mean this is the only part of the manual I've seen which is something like 10 pages .. tho it might be just the fact it's different for left and right.
Ok in this case does anyone know if the fork lift includes all the parts needed #49378-09 and if it is all the parts for both tubes or just one
Additionally what's the part number for type e hydrolic oil halrey says we should use - can't find it on the list
Old 05-20-2019, 09:58 AM
grbrown's Avatar
grbrown
grbrown is offline
Wink
You'll find the right oil on the shelf at your local friendly Harley dealer! Alternatively you can order from Jersey H-D (that's the original Jersey, not the US one!) and VAT-free. Take a look at their website. You can often find details of kit contents by using the H-D USA website, going to the Shop tab.
Old 05-20-2019, 10:22 AM
Souzafone's Avatar
Souzafone
Souzafone is offline
The kit is per side from HD. I've never seen one leak that way, usually the oil accumulates on the tubes. This looks like it was poured into the seal covers. Also fork oil tends to be blackish.
Old 05-20-2019, 11:26 AM
hscic's Avatar
hscic
hscic is offline
Perhaps my how-to thread will help...there are also youtube vids like delboy garage that are pretty good.
https://www.hdforums.com/forum/sport...placement.html
It is not a big job as you will see.
Old 05-20-2019, 11:36 AM
Mihail Petev
Thanks everyone I'll check .
Interesting thing is doesn't feel like oil leak as well - tried rubbing it away and the only thing that worked was a bit of steel wool
What else could it be tho I'm thinking maybe there was a water pocket stuck in there and made a bit of a rust leak
Well will drive it for a couple days see if it comes back then it should be oil I guess
Sorce (05-22-2019)
Old 05-20-2019, 11:48 AM
whylee's Avatar
whylee
whylee is offline
Pretty easy job replacing the seals, also any fork oil will do, nothing special is needed.
Old 05-20-2019, 01:21 PM
Scarydog's Avatar
Scarydog
Scarydog is offline
That looks more like the chrome beauty cap is rusting underneath. Pop that cover off and take a look. Its not tight to the tubes. You can also pop the rubber dust cover to inspect. The rust may be from a worn dust cover and its the seal reataing ring thats rusting.
Old 05-22-2019, 01:34 AM
hscic's Avatar
hscic
hscic is offline
I agree, looks like rust....also looks like rust along the rim of the slider where the cap seats on the slider. As suggested above, pop the cap and inspect...you may find the source or the cause.
Quick Reply: Possible fork leak ?
