Sportster Shifting Hits Neutral
I have a 2005XL1200 Custom with only a few thousand miles on it, but from new I have problems shifting from first to second when the bike is hot, too often I catch neutral instead of second. That's a problem when leaving a stop sign in a bit of hurry. I'm trying to be very conscious about not releasing the clutch too soon, but still this happens. Does not seem to be a problem when cold.
Dealer said all is OK at the 1K, but it was doing it then.
Any ideas? Change the tranny oil? Change shifting technique?
P.S. I won the Sporty!
RE: Sportster Shifting Hits Neutral
ORIGINAL: nine11c2
My softy does it when I shift lazily...
And I always wear steel toed boots, which give the lever a 'full jolt'.
If you happen to wear 'normal shoes' or whatever that have some "give" in the toe when upshifting, it's even more important to give the lever a very firm snap.
ORIGINAL: OldFenderGuy
I'll admit that after 35+ years I still do it from time to time, even though I know better, and feel like an idiot when it happens.
