Sportster Shifting Hits Neutral
RE: Sportster Shifting Hits Neutral
ORIGINAL: 04XL1200C
Lifting the shift lever higher if you are only shifting it into nuetral should correct that problem. Sounds like it is your shifting technique causing the problem.
Just my penny.
Just my penny.
I did that for the first time yesterday. It was just a lazy shift. I was pre-occupied with a female occupant in a cage beside me. Thankfully, I realized I had missed the shift before I let out the clutch and reved the engine in netural. That would most certainly have KILLED the "cool factor" I had working for me.
But if that isn't the problem, you might try changing to a synthetic oil in the tranny. When I changed from regular Dino tranny fluid to Moble 1 V-twin in the tranny, the shifting effort was noticeably reduced.
Have hit the neutral a couple of times, mostly when downshifting in front of a traffic light. Being a relatively fresh rider, I don't think I can blame the the bike for this. To avoid future embarrassment,I always look for the "N" when waiting for thelights to change.
RE: hitting neutral
I have the same issue however, it is not due to lazy shifting technique. It literally happens everytime i try to shift to second gear. I just had my bike in for the 10k service and i assumed it was just a clutch adjustment. But it was the same and progressively got worse over the next three weeks. When i upshift no matter how swift i try it hits the second gear and bounces back into neutral. Also i just noticed today that my primary case is leaking about one drip a day. Dont know if that could be a contributing factor. Im looking to see if anyone has exerienced this. Not accidentally hitting neutral bc i of course have had that embarrassing feeling of everyone just watched me wind out neutral bc i missed second gear. Especially when a honda shadow beats me off the line bc of it haha.
Specs:
2011 nightster 1200
Screaming eagle mufflers (reflashed ECU)
Stock a/c
Standard oil
History of shifter seal leak
Thanks
Specs:
2011 nightster 1200
Stock a/c
Standard oil
Thanks
