Turn signals and Horn stoped working?? What is this? Help
HI HDF,
My turn signals and horn just stopped working this morning when I had the motorcycle running on idle. What could be the cause of this and where should I look??
a little background:
I put a new turn signal in the right handlebar because I smashed it a couple of years back and hadn't ridden since because I was living in another country. Earlier this month, I soldered the one turn signal into the right handlebar wiring and connected it to the bike via the usual plastic connectors last night. Everything was working fine. Then, I put exhaust wraps on and let it run on idle for ten minutes or so with a few turns of the gas. before I shut it down the blinkers and horn weren't operational. What could this be?
thanks for any help guys, i don't know where to turn next to figure it out
That looks normal to me but I am not an electrical expert by any means.
When I relocated turn signals and changed handlebars, I pinched a wire where the wires mount into the controls by the grips. That's the place I would know to look. Did you change anything up there? BUt, it could be pinched anywhere along the frame, or moisture could be on an exposed wire somewhere.
