I need a new horn. It currently sounds like a sick duck.
There seems to be a ton of options online.
Will any of them work? or is there a certain type/model I should be focusing on?
There are a lot of options...not sure what you have but I am assuming your have the round horn between the front down tubes. No one will hear that horn IMO.
I relocated my horn between the cylinders with a touring horn like this...
I had the chrome cow bell on the side that got replaced when I relocated the coil. I got a 8$ one off amazon and installed it on the bottom of the frame similar to the setup DK customs sells. Still have a horn and looks way better IMO.
WOW - that looks cool!
The one on the bike was a snail shell design.
I was out and stopped at O'Reilly and picked up a wolo. It's bigger but it fits. I like it enough. I figured I could always bring it back, but it works.
If you don't mind plastic, the wolo is a good horn...and it's loud.
The stock horn on my 2017 SuperLow is pretty loud. It has the cow bell cover and is situated between the cylinders. I suspect it could be relocated easy enough without the cover.
