Sportster 1200S brake lines
Hey y’all. Looking to put some taller bars on my 98 sporty S. I’ve been looking for bike specific extended brake lines for the dual disks. No luck..would any of you happen to know if extended lines for another bike will work? I’ve attached some links to two sets as an example. Thanks!
https://hillcountrycustomcycles.com/...dual-disc.html
https://www.partsgiant.com/p338002-d...SABEgI6SfD_BwE
Hi Mumble, welcome to the forum! Coincidentally I'm also looking for SS braided lines for my '99 1200-S. I'm just looking for stock lengths though. Here are 2 links I recently received from another forum member. They have stock sets, and maybe they can customize a set with the lengths you need.
Good luck! Whereabouts are ya in ATL?
http://www.helperformance.us/hel-bra...1999-2001.html
https://us.goodridge.com/performance-motorcycle
Here are 3 threads related to the Sport models. I thought you'd like these for your archives. Post up some shots of your bike in the 1200-S owners thread below!
https://www.hdforums.com/forum/sport...rformance.html
https://www.hdforums.com/forum/sport...-s-riders.html
https://www.hdforums.com/forum/sport...-and-pads.html
Sorry I didn't get far enough to tell if the lines in your links will work; I'm not that seasoned in brake line replacing. Hopefully you'll find the ones you need. I'd call a company's support line and have them help figure out what you need. East Point, yup. Near the airport; my 2nd home. I'm up in Acworth.
I have a 2002 1200S.
I replaced my bars last fall. I went with kits from Magnum Shielding, and I strongly recommend doing the same - it's just too easy not to. You will need to purchase both the upper and lower brake line portions on account of our dual disc brakes.
Here is the link to Magnum Shielding lines for our bikes: https://www.magnumshielding.com/inde...=4&bike_id=631. That is for black lines, you can change the color in the upper left corner.
@Mumblemouth our stock bars have a height/rise of 4.5". I believe the stock upper line is 15", but @Magnum Shielding will know for sure; they are incredibly helpful. Anyways, subtract 4.5" inches from the height of your new bars, and that delta is approximately the length you will want. For instance, if your bars are 8" tall, order a +4 kit.
Feel free to PM me if you have any questions.
Magnum Shielding (04-01-2019)
Local, did you also do the rear line? I'll be doing my lines soon, front & rear, and wondering if it was a PITA to do the rear and fish the hard line from left to right to get it to the master cylinder. As well as the brake light switch, how was that to deal with? Thanks!
I didn't do the rear line (yet). I am trying to figure out which route I am going with forward controls before I do that. I may be going with Softail forwards which relocate the master cylinder, requiring a new, longer rear brake line, so I am holding off for now. It does look like a PITA to do, although my perception was that the Magnum Shielding lines were relatively malleable and would be able to do route to the rear. But, again, I haven't tried so I couldn't say for sure. If you are referring to the front brake light switch, I guess I was lucky in that I didn't have any issues. I just kept everything assembled and together as well I could.
OK thanks. Actually I was referring to the rear brake light switch, which could be a PITA because it's not easily accessible. Once I get going with this I'll post up some info on how the install went. I'm hoping to have everything ordered this week and get the lines installed in the next few weeks. I'm doing new tires, new brake pads, and cleaning the calipers at the same, so I'm coming up with a game plan right now.
MikeBel (04-01-2019)
