jet kit
jet kit
Okay guys I just got my jet kit in the mail and it says the I should go in from the underside of the carb because it is easie. The installaion directions say that I should stay out of the top of the carb becaue the slide diapram can be extremely difficult to reinstall without splitting or pinching the rubber. I have never been into a carb, so I am going in blindly. I am askin for some avice or tips, please help me before I make mistakes.
when the directions tell me to "drill out the silver plug that covers the idle mixture screw, and use a sheet metal screw to lock into the plug and pull it out, I get a little concerned.
also I am putting on forward controls next week, any advice?
also, how do I get the stock flanges off the header to reuse them?
RE: jet kit
There is a lot of great information here on the forum so read it and follow it and you will be ok. It isn't necessary to open the top of the carb for what you want to accomplish. An extra set of hands is always helpful if you have someone to help you. I agree with the take your time advice for sure.
RE: jet kit
This can be done with the carb on the bike. Or so I've read on here before, I suggest you take the carb off.
Here are a couple of good articles on this. I had never done any real carb work either, and was very aprehensive about taking a drill to the carb. It will be ok.
http://www.harley-performance.com/ha...r-jetting.html
http://www.harley-performance.com/ha...arburetor.html
Good Luck!
Good Luck!
RE: jet kit
The drilling was the easiest part.The drill went right in the plug and spun it out in like 3 turns.You will need to atleast losen the carb to get to the bottom of it.The instructions that ****** has are the ones I used.https://www.hdforums.com/m_190110/tm.htm.
RE: jet kit
Okay guys thanks, I got the jet kit for $18 dollars from ebay. now when that plug is pulled out and all the wok is finished, do you replug it with a new plug, or just leave it?
now someone said to:
"You'll need to pull off (or cut off) your stock mufflers then slip the flanges over the end of the pipe."
what exactlydoes this mean? I know the flanges have to come off the stock mufflers, so I have no problem doing what it takes to make that happen, but then how do you get those flanges on the new pipes? from what I gather the new pipe diameter will be much larger, so how will they fit?
thanks in advance!
thanks in advance!
RE: jet kit
Header pipe flanges, there's just a split retainer ring holding them on the end of the pipe, slide the flange back, pop the ring off, and flanges slide right off. New pipes should have the same retaining groove for the split ring, or they'll come with their own flanges..........Otherwise you probly got the wrong pipes for your bike.
The carb stuff is simple, just read through Rahlows link that someone else posted.
