venting your crank case
has anyone vented thier crank case? there a good artical on xl forums in the bottom end posts. I have the same bike he has and don't have the problem he has yet, but if you read all his post he put on a heck of more miles than I do.( I would do a link,but i'm not very good at links) and so far it's working great for him. it's a good read if your loosing oil.
RE: venting your crank case
I am not using oil but am getting some on the filter. I saw that post and am going to do it with some changes. I am going to disconnect the hose from the crank case to oil tank and put in a pcv valve on the engine side. Here is where I am doing it different; I am not using a tee to the oil tank that will just vent to the air, I dont want blow by in there. Also I will block the breather bolts on the rocker boxes since it will breath through the bottom. The pcv valve will create a vacuum in the crankcase so there will be no leaks. I plan on doing this tomorrow if Neinfeldt in Wisconsin Rapids has a pcv. The ironheads breath through a bottom end breather timed with the oil pump and this is similar but better since the pcv will be more air tight.
Had to order the valve but tried an auto pcv. Went for about 30 miles and noticed the oil is about 20deg cooler. I hit 110 and cruised about 65 so it wasnt babying it. My temporary job cost $10 and the valve I ordered was 30. Well worth the cost to keep oil out of the a/c.
I been seeing how everybody has been venting out of the breather and there are all different ways of doing it, and when it's all said and done it seems to be the same way indirectly. right now I have a s/e and it's vented to the carb. I have a b/s ready to be put on and was thinking of making some elbows to vent back to the carb like the s/e and stock filter does. then I came across this article that guig and my self read and it made sense so I'm exploring that option now and kind of like quig's idea. and hope to get some more feed back on his change.
Yes the valve is where the tee is in his pictures. The plastic line is just un hooked. The car valve has spit a few drops of oil but its not air tight so it cant create a vacuum in the crank case. Later this week I will have a better valve. I think the oil is cooler since blow by isnt being forced into the oil tank.
I left the butterflies in the heads, also I found a oneway vacuum valve on my wrecked explorer works better than the pcv valve. Kings OL We will be at the Cant afford Sturgis party in Dexterville Aug 3-5 it sounds like a good time or the S.O.O.W. party in Eland on the 21st.
