Turn signal extended switch cap replacement
#41
Ok fixed my short, pinched wire, and the bike is back together now. Ledt side extended right side not. For this moment it is what it is. I will order a complete set of black ones with extended turn signal caps.
It has to be a full set because what get this started was the factory black ones were worn out and unreadable. So I will order new ones and when convienient to me, I will install them.
FWIW I called HD dealer today and they wanted $62 plus parts and tax to install the right side switch. Not worth it to me.
I will go back to the black ones so I can have the extended. Or I might not order them at all and forget the whole thing.
#43
#44
#45
#46
With key caps you can remove the switch from the housing and it is very easy. To fit the extended turn signal caps you have to put the cap through the front of the switch opening and then offer up the switch from behind.
It is fiddly and you have to be careful if you don't want to scratch off any paint.
I have fitted two sets and it was no easier on the second bike.
WKNDS (10-12-2020)
#47
Installing standard caps was a piece of cake, mostly because as Andy pointed out, you cannot assemble them and slide back into place. The extended tabs make a HUGE DIFFERENCE. The left side went in fairly easy, but the right, never worked properly and I ended up rigging it up. My idea worked, and held up, but I would have preferred just using the cap as designed.
I will not try that again on my present bike.
#48
#50
crash_override65
05-24-2016 09:04 PM
foxtrapper
06-17-2014 12:39 AM
