Slop in brake pedal
hscic (01-06-2019)
hscic
Yea I remember reading your thread, and part of the limitation, is a built in hard stop for pedal height, that I do not see a reason for, personally.
Are the brake rods made from hardened steel? I would not want that bending, if I made an adjustable one. One other thing I had wondered about, is the position of the mids themselves. Seems if they were slightly farther to the rear, it would automatically point the front of my foot down (I am short legged), making for quicker brake activation. Right now it seems to take a fair amount of pedal to actually feel the brake take hold. Pad thickness looks fine on the rears too.
Are the roadster controls mounted to a different location on the frame, or just offset to the rear a little more?
Ok looked a bit closer at XR's and those are too far rearward and up too high for what I want. So will have to keep the gears turning for now.
Will look for adjustable rods, and a pad to raise the top of the pedal till I get it where I want it.
The brake pedal hooks to the clevis with a press pin on a Softail. Not sure about yours. On mine, it requires you to use a small c-clamp with a nut on the end to squeeze it it. Then it has the washer and Carter pin you bend over.
I have seen them loose since it will go in and washer and Carter pin will work without it pressed in.
