Does anyone know of anyway to relocate the brake light on the nightster?? There would be some room to drop the rear even more if the taillight was mounted differently. Any suggestions?
If you install the HD or Kuryakan run/brake/turn signal module which converts your rear turn signals into run/brake/turn indicators you could eliminated the center brake light. The downside being reduced visability. I like using the module with all 3 lights for added visibility.
There is no tail light on the Nightster; it uses the signals for run/turn/brake lights. I think you're referring to the reflector under the fender in the back. Just take it off.
[align=left] [/align]
