Need advice - left turn sig not working
Guys, I need some advice on where to start. I was out riding yesterday and my left turn signal stopped working. The right side works fine. The left worked a couple of times yesterday with front, rear and indicator lights working, but then later it had nothing when the button is pushed. I'm guessing it's in the switch itself. Can the contacts be cleaned or do I replace parts? Thanks for any advice.
MikeBel (12-04-2018)
So remove each bulb and check that it looks fine. You have a fault and bulbs can do odd things! If for example you have a dull bulb that seems to be working, replace it. Swap your bulbs from the left side to the right. If the fault follows the bulbs then replace them both. If nothing has changed then it's down to chasing wiring and grounds. If you have disturbed the left switch housing at any time take a fresh look inside, as it is all too easy to damage one or more of the wires. Dogged persistence will probably solve the puzzle!
The day after I posted I went out to the bike (which hadn't moved since I parked it w/ the signal issue) and with it just sitting there on the kickstand I tried the turn signal and it worked. If we get some warmer weather I'll take it for a spin to see if it'll act up again. I'll try your troubleshooting tip and will also just start following wires and cleaning things up. The bike's is turning 20 yrs. old, so there's work to do.
Thanks Graham! I definitely have an electrical gremlin. (And no gremlin bell yet for the 1200! Coincidence?)
