1999 Harley 883 XLH Carburetor Problem
I'm trying to get someone who has more knowledge on the stock Keihin carburetor. I've had my bike for 4 months now, I rebuilt the carburetor and cleaned it completely but when I get on the throttle the diaphragm pump doesn't push more fuel in. It's just a single squirt then dies past a quarter throttle. I think it may be the spring not working but I dont really know what it would be like working properly. Thank you in advance.
Are you having issues?
Is the nozzle clogged? Do you have the pump diaphragm installed correctly? It only squirts a bit as you open throttle, not continuously while it's open. What jets do you have? How many turns out is your idle mix screw? Have you replaced the manifold seals, especially at the heads? All your vacuum lines are tight and in good shape?
John
John
http://sportsterpedia.com/doku.php/techtalk:evo:carb01
John
John
IIRC, I don't think that exploded view above shows the idle mix screw, since it's set and sealed at the Keihin factory for HD.
John
Good deal on finding the problem. Yeah from what I have read it is a common mistake, the picture in the previous link I provided gives a good view of how it should go in. All those little parts in there would give me a headache if I ever had to rebuild my carb. No reason to feel stupid, you came to the right place to get info so you could figure it out.
diddlyd
Carburetor Related
12-19-2015 11:17 PM
