nightster issues please help.
RE: nightster issues please help.
A couple things that might help blackie... I have scraped my exhaust on two occasions while riding my 1200N... When you are turning right... Keep in mind that it is preferable to be near the left side of the lane before the turn... This will enable you to lean less sharply and accelerate a little more through the corner. Both times Iscuffed my lower right pipe were a result of turning too slowly/leaning too far. I considered it to be rider error on my part. Also, forward controls do help greatly with the exhaust heat issue.. Especially if you go with a larger peg set (e.g. FS skull pegs).
Good advice lucky... You know you can also just heat up the pipes and scrape the burnt rubber off with your thumbnail... This is testy of course, because if you touch skin... OUCH! I have used this technique a few times though, and it worked very well and left no marring/scratching.
