Windshield glare on hi beam
#71
Moving the U slot would if anything lean it back a little more, although that would be easier to assess by doing some measurements and marking out new mounting holes onto the brackets. It's a shame we're all so spread out and can't get together for a beer to take a closer look!
#72
Thinking out loud! Consider cutting off the upper U mounting slot, then creating a fresh one level with the L bracket above it (or below in your photo). Cut off the bottom mounting and redrill at the appropriate distance below the new U mount. Would be worth tracing the current mounts onto paper or card, so you can play around a little with seeing where the 'new' mounting points can end up, also how much rearwards they will move the shield.
Good thinkin' GB !
Beers' on me !
#73
Gr
Look at the top pic in post #65. That is exactly what I had done. Great minds! And it is actually a slot. That is the one I am considering deepening. The pic of the whole uncut bracket is the right side one. I didn't want to start hacking on both till I figured out what was going to work.
One thing about this project is you can think it out all you want but not until you do it and start fitting do you see what will or will not work. For instance, I tried to have the right side bracket on but with it moved up it REALLY interferes with the throttle cables, so that is a hurdle I have to jump when I get to that one.
I believe my next step, after bouncing it around in that empty space I call my head, is I will deepen the new slot, AND trim the inner curve of the windshield. I think that will be easier than welding and cutting again on the bracket. I can weld but sometimes the welds aren't as pretty as I hoped. Especially on a chrome piece.
The pic of the bracket on the floor is the right side one. The window trim on it was put on by PO to keep it from rubbing the throttle cables. That will be a big hurdle. Have to do my famous sit-n-stare till it comes to me.
I go in for my eye procedure in about 1 1/2 hr. It's only PRK but they say I have to wear a protective contact on both eyes and will be very irritated for 3-5 days, so not sure when I will get back on it. Hopefully soon. This is nothing serious, just a touch up after my cataract surgeries (yea I'm old) this summer. Just annoying, but hopefully I will end up with 20-20 when is all done.
Keep the ideas coming. I wish I had posted a shot of how much the right bracket is in the way of the throttle cables, so you guys could post your thoughts on it.
Catch ya'all later.
Catch ya'all later.
#75
#76
We've trodden similar paths. This is my 1990 Glide, with a shovel glassfibre batwing, for which I made new brackets and installed myself. The following photo doesn't show them very clearly, but they are somewhat similar to yours and took a lot of effort to get right, avoiding conflict with 'stuff' and getting the shield angle and height right. Bit of a nightmare, but got there in the end! I had the original batwing mounting brackets, but gave up thoughts of modifying them and eventually made new mounting brackets
#77
Gr
I see it now! Must be the time difference across the 'pond'!
Catch ya'all later.
Catch ya'all later.
#79
#80
