panicked at a safeway
Old 07-02-2007, 01:27 AM
128auto's Avatar
128auto
128auto is offline
Default RE: panicked at a safeway
Yes or no, my buddy uses 20w50 Pennziol oil on his 05 883 for over 20,000 miles, still running strong. As long as the oil has the same SAE rating, you should be just fine. If you are in the middle of the desert, would you choose not to add oil or add car engine oil? You have the answer
ORIGINAL: mrsr71
ORIGINAL: saltlick
Just plain old car oil works right?
Nope, not on an air cooled V-twin.
Old 07-02-2007, 09:53 AM
SportyPig's Avatar
SportyPig
SportyPig is offline
For what it's worth....the owners manual says to use a Heavy Service Diesel motor oil in this type of situation. I know very little about motor oil, so I dunno. And I doubt that Saveway would have the Diesel motor oil. Certainly better to run car oil, than no oil. That's for sure!
Old 07-02-2007, 10:09 AM
cHarley's Avatar
cHarley
cHarley is offline
FYI - the desiel designation will be noted on the back of the can by the letters "CF". Many better auto oils carry this designation.
Old 07-02-2007, 10:10 AM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
ORIGINAL: mrsr71
ORIGINAL: saltlick
I disagree. I know lots of people that use a "car" oil, some dino, some synth. None of them have ever had a oil related failure.
My Ironhead has had nothing but Pennzoil dino 20w-50 put in it for the past 30 years. No problems due to oil type ever.
Old 07-02-2007, 10:14 AM
KeithB's Avatar
KeithB
KeithB is offline
Big Kahuna HDF Member
you realy only need motorcycle specific oil if it also does the clutch, which out Big Twins do not. So no biggie
bobbyd3
Oil Archive (no new posts)
17
06-07-2022 03:02 AM
giacomo56
04-22-2017 10:50 AM
BigD48
22
12-21-2013 01:26 PM
harris48cars
08-09-2011 05:29 PM
rotorhead
03-31-2009 04:43 PM
Quick Reply: panicked at a safeway
