Looking for additional rear lighting options for sporty
Get a BAL brake light. https://www.brightasslights.com/site/
Then get a run/turn/stop conversion and LED's from Custom Dynamics for your rear turn signals.
You could add an LED Run-Brake Light to your license plate-
Or an LED License Plate Bolt Light-
You can see lots of different options HERE.
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Several folks here have bought this smoked, low profile LED tail light from amazon. It's a good value-
There are a ton of retailers for LED tail lights at various budget levels. Custom Dynamics makes solid gear but is not cheap. The one above is a known good piece of gear that won't break the bank.
You didn't say what year your bike is. Newer bikes use a canbus system that doesn't require a load equalizer if you install LED signal lights. Older bikes do require that unit or you will have hyper-flashing. Custom Dynamics makes a nice box for this. It fits under the seat. Works great.
https://www.customdynamics.com/vehic...oad-equalizers
Custom Dynamics also makes a Run-Turn-Brake unit that turns your rear signals into run-brake lights as well, can strobe your brake-signals to get attention, etc. It goes inline with the box above, fits under the seat. Really excellent for safety.
https://www.customdynamics.com/smart...models?cat=107
You will need LED signal lights for the rear, at least for any of the above to make any difference visually. Again, a ton of options depending on budget.
https://www.moonsmc.com/collections/lighting
Custom dynamics makes great LED inserts as well, you can count on them to last a long time but are not cheap. You'd have to look through their site to choose what is right for you.
I bought a few 1156 RED LED lights from Amazon. They are bright as the sun. I've used them for a while and no issues. if they burn out, then I'm not out very much coin. They look like these ones-
That is what they look like with the led tail on my bike-
What year and model of Sportster do you have? There's quite a few options available, but which ones you can use depends on your motorcycle.
__________________
Custom Dynamics® - EVERYTHING To Light Up Your Ride!®
15 Cypress Drive
Youngsville, NC 27596
sales@customdynamics.com
http://blog.customdynamics.com
Review Custom Dynamics
Phone: 800-382-1388
15 Cypress Drive
Phone: 800-382-1388
