XR 1200 fast idle
Old 07-21-2019, 06:53 AM
Devils Cutau's Avatar
Devils Cutau
Devils Cutau is offline
Stage IV
Lucky enough one butterfly screw was only slightly loose. as a precaution I removed both screws, checked the threads and lock tight both of in. THANKS TO YOU GUYS YA JUST SAVED ME MOTOR as I am sure they would have ended up inside the motor eventually. SO I OWE YOU GUYS A FAVOUR. ANYONE IN NSW NEED A FAVOUR OR HELP LET ME KNOW
The both lines that come from the air box to the top of each Rocker Cases have cracks so i have ordered a set of those which will help
I checked every other bolt, screw, nut on the bike as I do ride a **** load of ks
Things get easy when you know somethings not right and you address the problem before it becomes a bigger one
The second is have a good crew of riders to help with advice
Old 07-21-2019, 02:20 PM
Midpegs's Avatar
Midpegs
Midpegs is offline
Received 1,119 Likes on 631 Posts
Oh **** , I've just stripped and inspected my carb and that's one thing I didn't check . What a wasted opportunity !
Old 09-25-2023, 12:26 AM
oleksa's Avatar
oleksa
oleksa is offline
Originally Posted by shanneba
I don't think there is a reset procedure.
• At idle (closed throttle), the signal is typically in the range of 0.2-0.8V.
• At wide open throttle, the signal is normally 4.0-4.9V.
Inspect ECM harness and TPS connectors for backed out terminals, improper mating, inoperative
locks, improperly formed or damaged terminals, poor terminal-to-wire connection, corrosion and damaged harness.
The TMAP VSS and TPS are all connected to the same reference line (+5V REF). If the line goes to ground or open, multiple
trouble codes may be set. Check the wiring and connections for the TMAP and VSS sensor also.
the rough way to check the wires at the TMAP sensor was trying to pull wires out of connector - one had snapped and was fixed (as as the problem)
chaos5
09-26-2018 10:00 AM
dj skuzzy
04-05-2015 05:18 PM
foxtrapper
03-20-2014 12:06 PM
carlgrover
EVO
02-06-2011 07:37 AM
onaride63
08-03-2010 03:14 PM
Quick Reply: XR 1200 fast idle
