Handlebars keep slipping
Old 09-17-2018, 12:40 PM
jquest's Avatar
jquest
jquest is offline
Default Handlebars keep slipping
Been using licks 10" non-knurled handlebars. I notice my bars keep slipping every few rides and I will have to retighten them. This is like the 4th time. Do these clamp screws actually come loose? It concerns me how I am still able to tighten the screws to this point it could be overtightened. Im not sure if this is normal. Are my clamps damaged or do the screw actually do come loose? Will knurling prevent this from happening again?
Old 09-17-2018, 12:47 PM
whylee's Avatar
whylee
whylee is offline
Maybe add a bit of blue loctite, knurling the bars will help give some bite.
Old 09-17-2018, 01:43 PM
MikeRC's Avatar
MikeRC
MikeRC is offline
Get a cheap knurling tool and do it yourself or wrap some emory cloth around the bars in the clamp.
Old 09-17-2018, 02:40 PM
Oddman's Avatar
Oddman
Oddman is offline
and some blue lock tight. knurling would help tremendously
Old 09-17-2018, 03:58 PM
Dante221's Avatar
Dante221
Dante221 is offline
Smile I did this:
Go to Home Depot or Lowes and get some sheets of aluminum mesh that contractors use to
hold plaster to drywall seams
A strip around the bars under the handlebar clamps holds my non-knurled Biltwell Chumps
really well...and YES use blue loctite !
Good Luck
Dante
Old 09-17-2018, 06:47 PM
08xl1200r's Avatar
08xl1200r
08xl1200r is offline
Some bicycle assembly compound would probably do the trick, this stuff is specifically made to prevent handlebars, seatposts, etc. from slipping and really works in my experience...several suppliers make it aside from Park
underwhelmd (09-17-2018)
Old 09-17-2018, 06:50 PM
saltlick's Avatar
saltlick
saltlick is offline
Good Luck
Dante
This! seen it a few times work great.
Old 09-17-2018, 09:02 PM
underwhelmd's Avatar
underwhelmd
underwhelmd is offline
I use that stuff on my mtn bike seatpost. Does work. Didn't think to use it on my bike-with-an-engine.
Biltwell specifies why they don't knurl their bars, claiming less clamping power between the different materials (bars/clamps).
The chrome biltwell flyers I had liked to slip every time I hit a pothole. It was dangerous, near loss of control at 60+mph. Tightened the friggin' things down tighter and no more slipping. Was probably past torque spec, didn't care.
The new non-chrome tracker bars do not slip at all with less torque on the clamps. Anyways, that Park tool stuff above should work to cure what the OP is experiencing.
Old 09-17-2018, 09:40 PM
whylee's Avatar
whylee
whylee is offline
Basically its lapping compound, I have used it and it works.
Old 09-18-2018, 02:26 AM
Andy from Sandy's Avatar
Andy from Sandy
Andy from Sandy is offline
Received 3,996 Likes on 2,550 Posts
The other thing to check is the screws are done up to the correct torque. I have found on some screws I would of stopped but a torque wrench showed I should of done a nut or bolt up tighter.
The FSM shows an order to do the screws up although I did mine to give an even gap on the clamp.
Quick Reply: Handlebars keep slipping
