Shock Pump
Does anybody have a recommendation for a good pump to use when running take-off air shocks. I don't really want to spend $50 ...
Good thing with Walmart is that you can return it promptly if it doesn't work for you.
HTH.
I get it.. $50 isn't that much, but I usually try to avoid buying from the dealership. 98% of the time I ride solo and run the shocks at 0 psi. Heading to Blues, Bikes and BBQ at the end of the month. Going to be riding two-up while down there. Probably the only time I will need the pump. Guess I'll bite the bullet... won't be the first time I bought a tool for single time use.
-gearhead
-gearhead
-gearhead
-gearhead
Go to a motorcross store.
I have seen and owned very small pumps the size (and actions) of a larger syringe.
Can take with you on the road, lasted many years.
Brand cost...unknown.
FWIW I will add quality is important if you desire accuracy.
With installing and removing the pump to the air fitting one can lose pounds of pressure, making
settings difficult.
Also a line/ junction to tie the two shocks air fittings into one air fitting is highly recommended by me.
settings difficult.
