Shock install tips
Old 08-27-2018 | 11:58 AM
splashback's Avatar
splashback
Default Shock install tips
I am getting some Progressive 412s delivered today. I do not have a lift for my Sportster. Any tips on getting them installed? Can I use a car jack with some blocks to help take the weight off the rear end?
Old 08-27-2018 | 12:38 PM
Scuba10jdl's Avatar
Scuba10jdl
You'll have to get weight of the rear end somehow. If the car jack is low enough you could do that. You can also get a 4x4 block and rock the bike up on to it, etc. More than one way to get it off the ground.
Old 08-27-2018 | 12:44 PM
nevil's Avatar
nevil
Try doing one side at a time. You might not need to jack it up at all. I never changed the shocks on my Sportster but did it that way on the Dyna.
Old 08-27-2018 | 12:56 PM
hscic's Avatar
hscic
Why do you not want to buy a lift? If you are going to DIY maintenance and upgrades, it will be worth the investment.
You can also make one i.e. DIY lift out of wood that works as well.
I have never not use a lift when changing my shocks...in fact, I use two lifts one for the bke and one for the rear wheel... it is just easier with a lift.
A car lift can work, just lift slightly and use the kickstand and front wheel as your balancing points to get the weight off the rear. Find a place where the jack will be stable like the crossmembers on the frame wihere there is a ridge
Old 08-27-2018 | 01:05 PM
underwhelmd's Avatar
underwhelmd
I thought craigthecarpenter 's homemade lift was quite good. It had side to side support:
post #10 in this thread shows it really well-
https://www.hdforums.com/forum/sport...sportster.html
Old 08-27-2018 | 02:40 PM
Souzafone's Avatar
Souzafone
If you do 1 side at a time you won't need a jack, but lining up the upper bolt while lifting the rear end isn't easy, but it is doable.
Old 08-27-2018 | 07:49 PM
Mborras1's Avatar
Mborras1
I used a scissor jack that comes with most cars and was able to get the tire off the ground enough to remove and install my 412”s. Use the cross bar furthest to the rear tire and you’ll be fine.
Old 08-27-2018 | 11:48 PM
08xl1200r's Avatar
08xl1200r
+1 on making a lift, they work great for Sportsters. I made this one and it will either end of the bike depending on where it is placed and was changing shocks in the picture...welded it together but there are plans on the web for simple plank and pipe designs that can be built with basic hand tools, used these as a basis for my steel tubing lift
http://www.nightrider.com/biketech/bikelift.htm
Synstars
10-26-2019 12:34 PM
keith t
11-01-2013 06:17 AM
elderberry99
02-18-2013 12:12 AM
Motown Strag
01-13-2013 03:56 PM
kzman
03-17-2006 12:10 AM
Quick Reply: Shock install tips
