Brakes / Wheels / Tires. Need some help.
2011 Forty Eight.
Ok so I’ve started gathering stuff for some upgrades. Currently already have SS braided front lines. Bought a set of fat bob wheels that came with rotors so I can do a 180 rear. I want to do the XR1200 caliper upgrade as well. I have some questions...
Thinking Avon Cobras. I’ve spent some good money on suspension and I want this to handle in the twisties. Do I stay with a 130 front or get a 150 front to match stock fat bob set up?
Second, I want to upgrade the rear brake as well. Going to a larger floating rotor with the “older” bracket. I’d like to do a SS line to match the front and I can have magnum shielding (they’re local to me) make me one. I think I would have to eliminate the brake switch though. Additionally could I do the XR1200 rear caliper as well?
I think this is it for now. At least with the XR setup I don’t think I’d have to change master cylinders.
Thanks!!
Bike currently
New wheels!
Thanks!!
Bike currently
New wheels!
Avon tyres are a wise choice - I've been using them on my Harleys since the 1970s! The Cobras are only available in the ususl custom sizes, however an alternative is the Storm family. I have them on my Buell and Sporty (SuperLow uses lower profile tyres than most other models), also on the rear of my Glide - with a Cobra on the front.
I suspect you will need a Storm for the rear (I use the XM versions). If you plan to use a 130/90 front then a Cobra is just the ticket!
It will only 'hurt' you if and when you slide off!
Tee Hee!!!!
Not many of us have tried out that combo, so I doubt if you will get flooded out with advice. As for being a 'racer', you know what tyre combo works well on sports bikes!
Tee Hee!!!!
Haha yup! I know sportbikes are 120 front / 170 or 180 rear. I also know that the curvature profile of sportbike tires are much better suited to turn in.
