Should this part of the engine move???
Old 06-28-2007, 12:58 PM
drum412's Avatar
drum412
drum412 is offline
Default RE: Should this part of the engine move???
IF it don't leak, don't touch it. They are held stiff by the compression of rubber o-rings. So if it's not leaking oil, don't worry about it. But for future reference, don't go twisting the tubes cause you may damage those o-rings and start a leak.
Old 06-29-2007, 12:05 AM
Starz26's Avatar
Starz26
Starz26 is offline
Thanks for all the replies, I will keep an eye on it and have it checked with the 1000 mi service.
I did not mean to turn them, just happened when I waspolishing the chrome and I happened to notice it.
Old 06-29-2007, 01:23 PM
WVHogRider's Avatar
WVHogRider
WVHogRider is offline
Considering the bike is an '07, you should probably stop by the dealer and have them take a quick look at it, as I don't think those should have any play/wiggle room in them at all. I could be completely wrong on that, but I know mine are tight, and unable to twist. The only time mine was able to twist was right after the my 1200 conversion when I noticed oil leaking from there. Have it looked at under warranty, before it becomes a problem!
Old 06-29-2007, 05:40 PM
Starz26's Avatar
Starz26
Starz26 is offline
Well, after riding for a while I checked it again and it no longer moves.....
Old 06-29-2007, 08:36 PM
Zeb's Avatar
Zeb
Zeb is offline
Yea, it sounds like some seals are starting to dry up or a head is coming loose.
The first thing I would check is the tightness of the head on that side. If it is indeed loose, then I also would check the other head as well. If both are fine, then I would just leave it alone until the seals dry up completely and the thing starts to leak oil from the tube, if that is the problem.
It's difficult to understand how the seals could dry up with less than 1000 miles on them, however. 'Might just be a bad factory assembly problem of some type.
It probably stopped moving once the motor heated up, like I said it might do in my initial post.
Gobike
07-01-2009 01:12 PM
lowglide88
EVO
05-06-2009 10:38 AM
blk n wht hog
02-16-2008 08:04 AM
crazeehorse
10-23-2007 09:18 AM
mizpiggy
09-26-2006 08:13 PM
Quick Reply: Should this part of the engine move???
