97 1200 custom blue smoke
Ok guys I'm looking for a way a can diagnose a problem I have. Apparently when I accelerate hard my bike blew out some blueish smoke. I know black smoke is to much fuel and blue is oil. Which isn't good. Can you guys give me some ideas how I can diagnose the problem. The bike does have pipes and air intake. Thank you
Check
1. Oil tank overfilled.
2. Oil carryover.
3. Breather hose restricted.
4. Restricted oil filter.
Do a compression test- check your service manual for compression pressure.
2013 XL 1200 is 200-225psi. Older models may be less.
You may be able to get a compression tester (12mm spark plugs) from the Auto Store loan a tool program.
Compression low on first stroke, builds up on the following strokes, but does not reach normal.
Improves when oil is added to cylinder.
Cause: Ring trouble
Compression low on first stroke, does not build up on following strokes.
Does not improve with the addition of oil.
Causes: Valve trouble
Head gasket leak
Incorrect pushrod length
The cylinder leakage test pinpoints engine problems including
leaking valves, worn, damaged or stuck piston rings and blown
head gaskets.
Rotate the piston to TDC of the compression stroke (both
valves closed).
To keep the crankshaft from turning when air pressure is
applied to the cylinder, engage transmission in fifth gear
and lock the rear brake.
Leakage greater than 12 percent indicates internal engine problems.
Listen for air leaks at induction module intake, exhaust pipe and head gasket.
a. Air escaping through the induction module indicates a leaking intake valve.
b. Air escaping through the exhaust pipe indicates a leaking exhaust valve.
2. Oil carryover.
Cause: Ring trouble
Head gasket leak
head gaskets.
valves closed).
RRider (07-12-2018)
Actually reading through the first comment it seems more like valve problems or head gasket. The compression jumped right up to 90 and did not build after that. How do i go about checking valves or head gasket. The head gasket doesn't leak oil. I'm new to messing around with 4 strokes. So valves are new to me but I'm a do it your self type of guy.
90 psi is barely enough to even run. Do a wet compression test. If the number is good on a wet test, your rings are shot to hell. Valve issues are super unlikely on a hydro lifter HD because that artificially raises the compression numbers. If your wet test shows no change, maybe then we can discuss a valve issue. These motors will typically drop to 0 compression when a valve issue is present, not like a metric bike going out of adjustment.
And always make sure you’re doing the compression test correct as CHarley points out. Bad procedure gives bad numbers.
RRider (07-15-2018)
