Need oil leak help
Old 06-11-2018 | 08:23 AM
JerseyDoug's Avatar
JerseyDoug
Question Need oil leak help
Changed the oil and filter in my 2011 XL1200C (25000 miles.) last weekend. (10 days ago.) Started noticing oil on the garage floor. First thought I had just gotten sloppy while changing the oil. Double checked the filter and drain plug. Both showed no evidence of a leak. Put down fresh paper towels and still getting oil dripping.
This weekend I had time to pull the right side cover off and noticed the bottom most hose attached to the oil tank showed evidence of a leak. The oil seems to travel down the line and then drip on what I think is the oil pump housing and then on down to the ground strap, on to a component of the brake system(?) and then on to the ground or around to the primary drain plug and then the ground. (Primary drain plug is tight, no leaks.)
However, I can't determine why it is leaking. The lower hose seems to be connected tightly (with HD band clamp) and I can't detect a hole in the line. Could it be that I inadvertently overfilled the tank and it is coming out the top and flowing down? I filled it with 2.8 qts and it came to the top fill mark on the dip stick. Usually I only fill it to the half-way point.
Any help would be greatly appreciated.
Thanks,
Doug
Old 06-11-2018 | 08:25 AM
Sam_48's Avatar
Sam_48
Clean and degrease everything. Then leave it sitting and check. This will make tracking the leak much easier.
Old 06-11-2018 | 08:30 AM
Ben221's Avatar
Ben221
There are a lot of sources in that area as I am working in that area on mine. . Tank send and return, vent lines for tank and crankcase, oil tank...
i would be surprised if if it was a line. I can see a little better with my battery removed on my older 1990 version.
JerseyDoug (06-11-2018)
Old 06-11-2018 | 08:47 AM
JerseyDoug's Avatar
JerseyDoug
Gave it a thorough cleaning yesterday and put fresh paper towels under it. Will check it at lunch.
Old 06-11-2018 | 11:16 PM
Hurricane 68's Avatar
Hurricane 68
Check make sure you have right oil filter for a sportster there are two different ones and one will cause bike to push oil back Thru oil tank pushing out vent. Been there I always and only use factory HD filters 63796-77a good luck. Wild Bill
Old 06-12-2018 | 04:19 AM
JerseyDoug's Avatar
JerseyDoug
Really? Well, when I did the oil change recently, I used a k&n filter for the first time. Looks like I’ll be changing the oil again!
Has anyone had a similar experience using K&N oil filters?
Last edited by JerseyDoug; 06-12-2018 at 07:03 AM. Reason: Additional information added.
Old 06-12-2018 | 11:14 PM
Hurricane 68
Default Just filter
Just change out out the filter and check and add oil to level. Used a aftermarket on mine once puked all oil out tank breather. Went thru a lot then found a article on the tube about difference in filters changed to stock HD one no more oil pushing out
Friends evo style did same thing used same type aftermarket I did funny I bought them from Indy shop said right ones not it also uses same filter as sportster as mine. So both now good to go.
Old 06-13-2018 | 07:33 AM
Sam_48's Avatar
Sam_48
Weird. I have used the K&N filter for the last two oil changes with no issue. Im not saying the problem doesn't exist but am curious how many riders/bike have been affected by using a different oil filter than stock.
JerseyDoug (06-14-2018)
Old 06-13-2018 | 08:05 AM
JerseyDoug's Avatar
JerseyDoug
Replied to your comment in the other thread. Thanks.
Looks like mine is leaking from the drain tube. Oil flows down the exterior of the tube and collect on top of the engine case where it touches it before dropping on down to underneath the engine. There is no oil dripping off the lower end of the drain tube. This should be any easy fix to replace the drain tube.
I am assuming I pulled it loose during a change when I tugged on it to get a better angle on the band clamp. My bad.
Thanks again. Much appreciated.
Old 06-14-2018 | 02:47 AM
SoftailBrian's Avatar
SoftailBrian
There was about 3 our 4 of us not to long ago that had the same problem. All were leaking from that bottom drain line coming off of the oil tank.I was changing the oil anyway so when I had the tank empty I changed out the hose.I'm using a K&N filter and have no issues with that. If you're going to drain the oil to check it out, I'd check that hose before you pull the filter off and have to replace that for no reason.
Quick Reply: Need oil leak help
