Clutch lever wont return without being pushed out.
Old 06-10-2018, 07:04 AM
Jsvwrestle's Avatar
Jsvwrestle
Jsvwrestle is offline
6th Gear
Default Clutch lever wont return without being pushed out.
I recently replaced the clutch cable on my 04 1200c and the clutch lever gets stuck about half way out. I adjusted the cable and it will make the lever go out all the way but then it is too hard to pull the lever to engage the clutch. Amy ideas where I went wrong. Thanks.
Old 06-10-2018, 09:14 AM
Sam_48's Avatar
Sam_48
Sam_48 is offline
Have a trace around see if there is a pinch point . Remove it from both ends and make sure it slides in its sleeve nice and smoothly .
Or you can cut straight to the mustard and open up the cases if you want to . See if there is push rod or spring issues inside .
Old 06-10-2018, 09:37 AM
Jsvwrestle's Avatar
Jsvwrestle
6th Gear
How do you know if there is an issue with a pushrod or spring?
Old 06-10-2018, 10:00 AM
cHarley's Avatar
cHarley
cHarley is offline
Did you follow the adjustment instructions in the Service Manual?
- completely slack the cable adjuster
- make the screw adjustment under the derby cover
- readjust for minimal slack in cable
cacomly (06-11-2018)
Old 06-10-2018, 10:08 AM
Jsvwrestle's Avatar
Jsvwrestle
6th Gear
Yes. Although I'm not sure that I have the adjustment on the screw inside the derby cover set right.
Old 06-11-2018, 09:57 AM
cacomly's Avatar
cacomly
cacomly is offline
If it worked fine before you replaced the cable then I'd start over again. Confirm the cable and ramp assembly are installed correctly and that the clutch adjustment is correct. Also check the cable is moving freely within the housing as stated.
Old 06-11-2018, 10:19 AM
bad tappets's Avatar
bad tappets
bad tappets is offline
Sounds like the ***** have fallen out of the ramp.
Old 06-11-2018, 06:11 PM
Jsvwrestle's Avatar
Jsvwrestle
6th Gear
That's not the only things ***** have fallen out of.. Haha. The previous clutch handle was the same way. The bike sat outside for a year and the linens were rusted that is why I replaced them. When. I drained the oil it was very milky as if water was inside.
Old 06-11-2018, 06:43 PM
Captain Itch's Avatar
Captain Itch
Captain Itch is offline
Sponsor
If you do not have a service manual get one . The Harley one.. If your oil was milky then yep run it and change it again ,all the fluids .. Good Luck ..
__________________
www.Captain-Itch.com
Old 06-11-2018, 07:01 PM
Jsvwrestle's Avatar
Jsvwrestle
6th Gear
Already changed it.
Quick Reply: Clutch lever wont return without being pushed out.
