Clutch lever wont return without being pushed out.
Old 06-12-2018, 08:04 AM
cacomly's Avatar
cacomly
cacomly is offline
Originally Posted by Jsvwrestle
That's not the only things ***** have fallen out of.. Haha. The previous clutch handle was the same way. The bike sat outside for a year and the linens were rusted that is why I replaced them. When. I drained the oil it was very milky as if water was inside.
Ok, if it was the same then you could have other issues. Perhaps the spring plate in the middle of the clutch is bad
Old 06-12-2018, 09:35 AM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,972 Likes on 1,344 Posts
It could be milky because the PO never rode it long enough to purge moisture from the oil. When you start the bike, you should always plan to ride at least 1/2 hour or so to make sure the engine gets fully up to temperature so any moisture is purged. Then your oil stays nice and clean and not milky.
John
Old 06-14-2018, 05:24 PM
Jsvwrestle's Avatar
Jsvwrestle
Jsvwrestle is offline
6th Gear
Took everything back off and adjusted and readjusted ***** are in ramp slack out of cable lever all the way in the lever still won't go out all the way without being too hard to pull and nearly bottoming out the adjuster on the line. Any ideas guys.
Old 06-14-2018, 05:48 PM
John Harper
Are you sure you have the correct cable? This new cable has never worked correctly? Can you post up some pictures of where the cable connects down at the clutch, so we can see if it's put together correctly? It's hard stumbling around in the dark.
You say the previous clutch worked the same? Have you checked for a broken clutch diaphragm? Maybe the clutch adjuster bearing on the adjustment rod has gone out? Maybe that's why the bike got put out in the rain?
John
Old 06-18-2018, 07:54 AM
cacomly's Avatar
cacomly
cacomly is offline
I suggest pulling the entire clutch and checking the spring plate. If it comes apart you cannot adjust out the change in the dimensions of the clutch pack
Brooks2131
09-19-2018 07:36 AM
peepa
General Topics/Tech Tips
16
10-01-2016 05:36 PM
CGLTD
02-12-2014 04:00 PM
tryus
04-17-2011 06:58 PM
so165
04-09-2007 09:37 PM
Quick Reply: Clutch lever wont return without being pushed out.
