Front signal lights
Front signal lights
My front right turn signal is working as normal, stays on solid and flashes when I press my right turn signal on, but my left will not stay on solid, but does start to flash when I press the left turn signal on.
Anyone got any ideas on what may be wrong?
Thanks in advance
Thanks in advance
Funny thing is when I tried the right (working) signal bulb on the left it wouldn't work, stayed the same; but went out and bought a new set of bulbs and the left one worked when I put the new bulb in. Tried to install the second "new" bulb for the right signal (figured I might as well use both new bulbs) and then neither light would work. Put the old (working) right bulb back into the right signal and both worked perfectly. Oh well, if that's how it wants to work, that's how it will work.
Andrewnc
06-27-2018 07:50 AM
