picked up some new pipes and I need your help
RE: picked up some new pipes and I need your help)
Looks like you're getting about a 50/50 response. I just installed a set of straightshots on my '03 1200 and used new stock HD gaskets. They're pretty inexpensive.
I couldn't imagine the SE gaskets are much more, so pick up a set and you should have no worries.
Sounds good, boxcar.
You might check with your dealersip. They've probably installed a bunch of these pipes already and may already know what jet to use on your application.
I know when I installed my SE IIs my bike ran fine (but louder). It wasn't untilafter installing the new AC setup I have that they had to rejet.
Not sure on how it is with the '05s though... Maybe you won't have to worry about it [8D]
