Best Oil to use in a 09 sporster?
lh4x4 (05-26-2018)
Nothing wrong with HD 360 or SYN3. You can run these in both the engine and transmission/primary.
Mobil 1 20w-50 or 15w-50 are popular for the engine.
HD filters when you pick up the gasket for the primary chain adjustment and o-rings for the Primary drain and Clutch cover.
If you decide to use gear oil in the primary/transmission read this first- not all gear lubes are equal-
https://www.hdforums.com/forum/sport...-answered.html\
Don't forget to adjust the primary chain and clutch
http://xlforum.net/forums/showpost.php?p=658119&postcount=4
