Crappy design and poor quality oem gaskets. I just replaced that same gasket last week. It’s the lower of the 3 usually as the top 2 are rubber. Cosmetic gaskets are a good choice.
No too much oil would not cause that.
Those gaskets/seals are a very common leak point, you can try torquing the bolts to spec but it's probably time for new gaskets
Watch a video on YouTube by “ 2 wheeled Rocco” for an pretty how to video. Make sure you let the lifters bleed down before torquing the 3 rocker assembly bolts. I think his video left that out.
Harley has improved their top end gaskets and I like them better than cometic gaskets. I've used OEM the last two times I've installed Hammer kits and not a smidgen of oil leak.
Which company makes better gaskets, James, Cometic, or Harley?
Having used all of those and more, I can say that the answer is: it depends.
I've had poor gaskets from all, and I've had great gaskets from all. A cometic MLS gasket is not always the answer compared to an HD one. Overall, they're all good and I would not hesitate to buy any of them. I tend to favor Cometic for almost everything, but there are a few rare cases where I use James because Cometic just hasn't quite gotten that specific gasket right.
For late model bikes, HD's gaskets are quite good. Leaps and bounds past their own gaskets just a decade ago.
And when in doubt, I've got a roll of Felpro gasket material (.030"/1/32", I know that's not directly converted, but close enough) that I cut to fit those special ones.
