Best products to clean/wash my bike?
just bought a H-D 2005, it looks they took good care of it mostly, however, looks like it never got washed properly, theres oil residue (looks black from dust, and what not), mostly on the area where oil filter is located, also under the engine and regular areas where it gets accumulated street residues that are picked up while riding, i want to make sure i use a good product that also won't brake the bank, a harley guy told me to use ever green, but just red in the forum that could damage finish or stain it.
Depending on the many different road surfaces there is a multitude of products required even if you don't use specific automotive ones.
Something to remove tar, something to remove brake dust, something to remove bird poo, something to remove bug spatter and finally something to remove dirt.
Once you get your bike clean then a good coat of wax or sealant or even one of the many new ceramic coatings to offer a long lasting layer that will make cleaning much easier in the future.
If the paint has swirl marks and you want to tidy it up then another range of products to polish the finish to a very high gloss before adding the wax or coating.
I do a bit of car detailing and so have many different products, some just to try and the regular stock of stuff that works for me.
For cleaning I use a pre-wash or snowfoam and then any of the car shampoo products will do a good job. I use the 2 bucket method to not reuse the dirty water to continue the wash process. I use an air blaster to dry the bike afterwards.
Can't answer that. Ceramic coatings require a good day to cure and I don't have a garage for my car so I have never used them.
There is a technique for proper application and if you get it wrong it will be very difficult to get off to do it again.
I will stick to using Finish Kare FK1000P sealant. It works great on wheels and stops the brake dust from sticking so cleaning is a breeze. The stuff lasts for about 5 months so it very economical to use. Works on metal and glass, probably plastic as well where a wax wouldn't.
I just watch a YouTube video of a guy using Marvel Mystery Oil to clean that stuff up. He just used a towel to scrub it off.
Even better are the Never Dull pads, they can get into hard to reach places.
