Rear brake light switch?
Was at the Harley dealership getting a new rear tire, the guy told me the rear brake light wasn't working and he could fix it for $150.00 and then went on to say something about the rear caliper could have problems being bled. The front brake light works so it's not a bulb. I looked at the rear brake linkage and don't see a brake light switch. Any help would be appreciated.
P.S. the funny thing is I checked my lights before I left the house and everything worked.
You can find things using a parts website. Your rear brake-light switch is in your rear brake line, close to the master cylinder, which helps explain the cost you were quoted. Looks like a b1tch to replace, so worth playing with the switch to check that wiring connections are clean and tight, to see if that wakes it up.
fugno (04-28-2018)
Received 2,199 Likes
fugno (04-28-2018)
save $125 or spend another $25 on speed bleeders
Having just seen your bike is an 09 it may not have ABS but for newer bikes that do it is a whole different kettle of fish to bleed the system.
I have a custom here in bits and the brake light switch is on the left side just below the left side cover.
edfromptowne
Electrical/Lighting/Alarm
11-05-2009 07:00 PM
