turn signal relay
It does. There are plenty of +12V powers around. You can even make your own with a fused link from the battery if all it needs is power to the alarm (this is what I would do, tapping in to BCM power can cause issues if it doesn't get smooth power). I was under the impression you needed a pulsed signal.
It's controlled by the BCM on CANbus bikes (which your 2018 is). It's under the side cover with all the other electrical stuff. There is no TSM or flasher. If your turn signals aren't working you'll have to replace it, but being a 2018 you will be under warranty thankfully.
I totally missed it was a 2018, my apologies to the OP, didn't mean to send you on a wild goose chase
Sorry, I don't remember the correct way to post but I have a question about this subject.. Turn signal relays. I have a 2007 Sportster 1200 Low, 10500 miles. The turn signals stopped working. Both front turn signal lights stay lit. Headlight is on. Both turn signal lights are off in the rear. Back light is lit but brake light doesn't work. I checked all bulbs, checked for loose connections in the tail lights. all fuses are good. The only thing I can think of is the flasher or relay. I'm not sure if it actually has one or where it is. Any help would be appreciated. Thanks Pap1951
John
Your 2007 doesn't have a relay as such but a TSM or TSSM or even a HFSM
Wiring diagram - 99949-07_en_v1.1 - 2007 Wiring Diagrams | Harley-Davidson SIP
John Harper (07-19-2022)
OldFenderGuy
06-04-2011 01:07 PM
