handle bars on sportster
I've never seen the point of high bars, but it is certainly worth considering your current riding position and if your current bars are contributing to your discomfort. My own riding discomfort, when I suffered some years ago, was between my shoulders and I was able to solve that by simply altering my bars. Adjusting them can change the angle and position of the grips quite a bit and is always worth a try, as it costs nothing and simply takes a little time.
If that doesn't work for you, then it is certainly right to investigate further. I found the problem I mentioned above was due to me reaching forwards a little, to grip the bars, but also gripping them tight. On longer rides especially that muscular tension transferred up my arms and into my shoulders. If you are able to identify if you have something similar going on it will make determining a solution easier. Took me many months!
A windshield may help, by taking wind pressure off you, which in turn may help to reduce any tension build-up. However a great improvement I found is ear plugs! Noise is bad, contributed to my problem above, and ear plugs were a useful part of the solution that eventually worked for me. They are cheap as chips and worth a try.
