Sportster headlight issue
Hi All!
I recently inherited my fathers 06 XL1200C. The headlight does not work on low beam. I pulled the bulb to check it and found that the socket that plugs into the bulb is melted...
obviously I need to replace that plug but I wanted to check the power for high and low beam to make sure that was intact. Using my dvom (multimeter) I got 12v between yellow and black with the low beam switch on. If I flick the switch to high beam I lose the 12v. I would expect to find that 12 V had moved to the tan wire. It shows nothing.... anyone have ideas?
Agreed. But I’ve looked for continuity to ground on the hot side... saw none. I had the switch Addy apart and all that looked good. I really don’t want to tear it down to the wire harness but may have to I guess. I was hoping someone would say “ that always happens, look at XYZ.” But no luck! Haha
Here is a link to the 2006 Wiring diagrams from the HD SIP portal-
https://serviceinfo.harley-davidson....f5312fb4f!!1!2
The stock bulb is an H4 60/55w, often replaced by an owner with a 110/100w bulb which exceeds the design wattage specs for the socket & wiring and this is often the result.
cacomly (04-24-2018)
Dale_K
Electrical/Lighting/Alarm
03-05-2016 07:42 PM
