48 stock exhaust project!
Old 04-11-2018, 06:26 PM
181fsc's Avatar
181fsc
181fsc is offline
Default 48 stock exhaust project!
I am currently running SS on my 48 and I'm wanting something different so here goes. I' going to see what these stock pipes will turn out like with looks, sound, and performance. I'll post pics as I go. Cut right behind where the baffle was welded in.
Removed packing and cut off the cat i assume.
Removed the baffle from sleave.
Drilled out larger holes in hopes of a different sound.
Weldeded back together.
Ground off the weld for a slick look.
Removed the paint and now ready to sand with fine grit. I am wanting to find a clearcoat that will hold up to the heat and leave them polished.
Old 04-11-2018, 06:28 PM
181fsc's Avatar
181fsc
181fsc is offline
Will I have to remap?
Old 04-12-2018, 06:44 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,201 Likes on 1,687 Posts
switch to a stock-ish stage 1 (slipons like) tune and auto tune from there to dial it in.
Old 04-12-2018, 07:52 AM
181fsc's Avatar
181fsc
181fsc is offline
That's kinda what I was thinking. Thanks.
Old 04-12-2018, 09:29 AM
Kenny94945's Avatar
Kenny94945
Kenny94945 is offline
Beautiful idea.
OEM appearance.
Modified for tone and backpressure.
And that Catalytic Convertor...removed like a poisonous tumor perhaps.
Good luck in your project goals.
Let us know how the tone turned out.
Old 04-12-2018, 09:35 AM
181fsc's Avatar
181fsc
181fsc is offline
Originally Posted by Kenny94945
Beautiful idea.
OEM appearance.
yes sir!! That's the idea.
Old 04-12-2018, 11:38 AM
Jak_Rak's Avatar
Jak_Rak
Jak_Rak is offline
VHT's Engine Enamel comes in a gloss clear. It's good up to 550°, which might be ok for those cans. They also have a clear in their Flameproof line, but it's a satin, not a gloss.
Old 04-12-2018, 12:57 PM
181fsc's Avatar
181fsc
181fsc is offline
I was checking this out last night but the gloss may work if its up to 550.
Old 04-12-2018, 04:13 PM
DK Custom - ST's Avatar
DK Custom - ST
DK Custom - ST is offline
Platinum Sponsor
Nice job you're doing there!
Check out Thunder Torque Inserts™ for a better sound as well as a performance gain. They will deepen the tone of the exhaust a bit giving it a throatier growl. They also give you a gain in low and mid range torque.
Here's what we did with the stock exhaust on a 48-
Here's a LINK to the TTIs.
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old 04-12-2018, 05:12 PM
181fsc's Avatar
181fsc
181fsc is offline
https://youtu.be/8U19Sx0el4k
Yes sir! I run the TTI's on my SS with no baffles and it made a big difference in low end torque.
DK Custom - ST (04-13-2018)
Quick Reply: 48 stock exhaust project!
