Rear brake pad change
Received 2,199 Likes
- open the master cylinder,
- take the caliper off,
- fully spread the pads to push the pistons back in the caliper,
- clean the parts up with a toothbrush and brake cleaner,
- install new pads,
- reinstall caliper on mount,
- *bleed*
Maybe get some speed bleeders and prepare to have your mind blown. You can bleed in less than 3 minutes. I dont know the speed bleeder set part number for your bike but, someone may chime in.
harleyrider4300 (03-16-2018)
The following 2 users liked this post by John Harper:
harleyrider4300 (03-16-2018),
wharg (03-31-2018)
wharg (03-31-2018)
i paraphrased the manuals and added the tooth brush/brake cleaner and left out caliper grease because I know people will pitch a hissyyfit about it. I use it in my pad backings and pins after checking for pitting and sanding/replacement if.
