No vent port on new aftermarket gas tank
Hello I am customizing my 05 sportster I bought a lowbrow custome sporty tank it came with a vented cap but not a vent port what do I need to do with my old vent hose that goes to the charcoal canister can it just be open or do I need to cap it off?
Get rid of it and the charcoal can. Plug the vacuum line to the carburetor or manifold. Mine went to the carb, just put a vacuum cap on it. If there is a hose to the aircleaner, plug that one off too at the aircleaner. The gas vapors get sucked into the carb, so plugging that is most important. The hose to the aircleaner just provides fresh air to clear the charcoal. The vapors come from the gas tank. Without the gas tank connected, the whole thing becomes useless.
John
John
Your carb probably has a vacuum line to the fuel tank petcock too. Make sure that one stays connected and in good shape. Otherwise you will get no gas flow.
Very common to delete the charcoal can. Minor surgery.
John
DynastyServices
10-03-2010 07:29 AM
